15 years agoCannot access memory at address xxx, stack overflow management ?
Hi, I have some problems with my Nios II design (running on cycloneIII, ssram cy7c1380d). Very often I have this error: "Cannot access memory at address xxx" for several addresses and then th...
15 years agoIt is quite hard to get a 'memory address fault' message.
The mmu fault handler for an OS might generate one. The MPU interrupt handler might (if the MPU is enabled). It is possible to enable a 'misaligned transfer' interrupt - whose handler might generate such a message. If you try even harder (and are psychic) you can enable an interrupt for accesses to unknown addresses on the Avalon bus, but usually reads just return ~0.
