15 years agoCannot access memory at address xxx, stack overflow management ?
Hi, I have some problems with my Nios II design (running on cycloneIII, ssram cy7c1380d). Very often I have this error: "Cannot access memory at address xxx" for several addresses and then th...
15 years agoAre you sure the "Cannot access memory" message is not generated by your application?
Maybe in the code routines you didn't wrote. I'm not aware of such a message in standard Nios drivers. Are you using a OS? Anyway, before all you must be sure your hw is ok. So it's correct you now focus on checking timings, especially if the error appears randomly. You can try loading a simple application which runs in internal memory and extensively test external memories data transfers.
