15 years agoCannot access memory at address xxx, stack overflow management ?
Hi, I have some problems with my Nios II design (running on cycloneIII, ssram cy7c1380d). Very often I have this error: "Cannot access memory at address xxx" for several addresses and then th...
15 years agoHi Cris and sorry for replying late,
My project is based on a NiosII (fast, debug level1) hosted on Cyclone III on a custom board : - The nios program / fpga firmware is stored in external flash (EPCS16) - The code is executed in external 2MegaBytes sram (cypress cy7c1380d) - Nios purpose is to manage external devices with SPI (2 SPI lines) - A push&rotary button is used to modify some parameters used in SPI communications (it generates interruptions) - these parameters are display on a LCD (onchip memory is used as a buffer between nios and LCD driver (vhdl)) - these parameters are stored in an external non-volatile memory (SPI FRAM) A timer is used to manage parameters: update (if button interruption appends before), spi sending and display. Most of the variable are global. The display routine is written is c++ and is quite complicated (I didn't wrote it, many vectors and objects are used to create the font and write the buffer). I have maid some tests with only the display routine in my nios, but there I didn't really find anything. The nios is more stable but I have 1 time the "cannot access..." error. So at the moment I am focused on hardware problems like checking sram timing (address setup&hold times)... Do you know what is the exact meaning of "Cannot access memory at address" ? Does it mean that the address is not reachable (hardware problem) or that the memory content is corrupted/not the one expected... ? thanks again.
