15 years agoCannot access memory at address xxx, stack overflow management ?
Hi, I have some problems with my Nios II design (running on cycloneIII, ssram cy7c1380d). Very often I have this error: "Cannot access memory at address xxx" for several addresses and then th...
15 years agomost of the errors are between StackPointer and FramePointer.
The Stack is growing downward, so a stack overflow should occurs in lower addresses ? Thanks.
