15 years agoCannot access memory at address xxx, stack overflow management ?
Hi, I have some problems with my Nios II design (running on cycloneIII, ssram cy7c1380d). Very often I have this error: "Cannot access memory at address xxx" for several addresses and then th...
15 years agoI reduce my code footprint to 181kbyte program size / 1866kbyte stack+heap but I still have problems.
I had several time these messages : "Previous frame inner to this frame (corrupt stack?)" and/or: "Cannot access memory at address @xxx", addresses are very close to the stackpointer. "Execution is suspended because of error. Watchdog has expired. Target detached." ... Before trying to use a bigger memory (4Mbyte instead of 2) or deeply modify my code (no recursive call inside), I would like to have more informations about these errors. Sometimes they occurs after 1s and sometimes after 5mn with the same use. In debug mode with runtime_stack_checking enabled, I don't manage to identify the source of my problems (IDE messages are not each time the same). Thanks for answers.
