20 years agoCancel DMA operation.
How to cancel DMA operation for alt_dma_rx_chan? DMA sequence: 1. alt_dma_rxchan_open 2. alt_dma_rxchan_ioctl ( ALT_DMA_SET_MODE_32 ) 3. alt_dma_rxchan_ioctl ( ALT_DMA_RX_ONLY_ON ) 4. alt_...
16 years agoI've met a problem associats with DMA, i want to receive data from UART through DMA, and store the data into a buffer in on_chipram.
As the handbook says, the alt_dma_rxchan_ioctl() function must been called correctly before can receive data. downside is my program, i don't know is it proper to call the function in that way, at least it doesn't work! --- Quote Start --- #include <stdio.h># include <stddef.h># include <stdlib.h># include "sys/alt_dma.h"# include "alt_types.h"# include <system.h> /* flag used to indicate the transaction is complete */ volatile int dma_complete = 0; /* function that is called when the transaction completes */ void dma_done (void* handle, void* data) { dma_complete = 1; } int main (void) { alt_u8 buffer[32]; alt_dma_rxchan rx; FILE *fp; fp=fopen("dev/uart","r"); /* Obtain a handle for the device */ if ((rx = alt_dma_rxchan_open ("/dev/dma")) == NULL) { printf ("Error: failed to open device\n"); exit (1); } else { /* Post the receive request */ if (alt_dma_rxchan_ioctl(rx,ALT_DMA_RX_ONLY_ON ,NULL)<0) printf("error set\n"); if (alt_dma_rxchan_prepare (rx, buffer, 32, dma_done, NULL) < 0) { printf ("Error: failed to post receive request\n"); exit (1); } /* Wait for the transaction to complete */ while (!dma_complete); printf ("Transaction complete\n"); alt_dma_rxchan_close (rx); } return 0; } --- Quote End ---
