20 years ago
Can you help me
Can you help me view my routine and find the error?
I post my routine here.
# include "system.h"# include "altera_avalon_pio_regs.h"# include "alt_types.h"# include "altera_avalon_timer_regs.h"
alt_u8 led = 0;
static void timer_interrupts(void* context, alt_u32 id)
IOWR_ALTERA_AVALON_TIMER_STATUS(TIMER_BASE, 0);
if(led==7) led=0;
else led=led+1;
int main ()
alt_irq_register(TIMER_IRQ, (void*) &led, timer_interrupts);
(when finished buiding,An error present at above line)
IOWR_ALTERA_AVALON_TIMER_PERIODL(TIMER_BASE, 0x20);
IOWR_ALTERA_AVALON_TIMER_PERIODH(TIMER_BASE, 0xBE);
IOWR_ALTERA_AVALON_TIMER_CONTROL(TIMER_BASE, 7);
while (1)
switch(led)
case 0: IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE, 0x01);
case 1: IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE, 0x02);
case 2: IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE, 0x04);
case 3: IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE, 0x08);
case 4: IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE, 0x10);
case 5: IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE, 0x20);
case 6: IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE, 0x40);
case 7: IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE, 0x80);
default: IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE, 0x01);
return 0;
the error messege list at the console window is:
make -s all
Linking hello_led_0.elf...
/cygdrive/d/tools/altera/kits/nios2/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/../../../../nios2-elf/bin/ld: region Chip_Ram is full (hello_led_0.elf section .text). Region needs to be 2704 bytes larger.
/cygdrive/d/tools/altera/kits/nios2/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/../../../../nios2-elf/bin/ld: section .rodata [00002020 -> 0000206f] overlaps section .exceptions [00002020 -> 000021c7]
/cygdrive/d/tools/altera/kits/nios2/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/../../../../nios2-elf/bin/ld: section .rwdata [00002070 -> 00003a7b] overlaps section .exceptions [00002020 -> 000021c7]
/cygdrive/d/tools/altera/kits/nios2/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/../../../../nios2-elf/bin/ld: section .bss [00003a7c -> 00003c8f] overlaps section .text [000021c8 -> 00004a8f]
collect2: ld returned 1 exit status
make: *** [hello_led_0.elf] Error 1
Build completed
In addition, I 'm not very clear about the function
alt_irq_register( alt_u32 id,
void *context,
void (* isr)(void *, alt_u32))
for the viod* context; could anybody give me a clear explanation
Thanks very much
1 Reply
    Well my idea is, that your program is to big (the hal library makes it really big). First, try to reduce the program size by setting the optimize size compiler option.
    Provide more on chip memory.
    Actually there is project template "Hello world small" for small memory footprints.
    Or use sdram instead of on chip memory.
    maybe there are already some solutions in the forum... you try the search function.
