tommmy
5 years agoCan you fix stupid scripts error from 19.1 to 20.3?
i can not use nios2 command to generate newlib, do you really checked the nios2eds scripts? such as nios2-newlib-gen, it can not work correctly at all! can you fix this?
and your script not compati...
EricMunYew_C_Intel
5 years agocan you try below:
Modify <installation location>/nios2eds/sdk/bin/nios2-newlib-gen:
include the following on the top of the script, before "usage()"
uname=$(uname -r | tr A-Z a-z)
if [[ $uname =~ "microsoft" ]]; then
windows_exe=.exe
fi
- tommmy5 years ago
I had tried before, not work.
I am pretty sure, the function build_newlib() in this script file is not right. the STAGE_WRAPPER file not generated correctly.
STAGE_WRAPPER=$BLDDIR/build-newlib-stage-wrapper
in file " build-newlib-stage-wrapper"
#!/bin/bash
# A script to intercept and short-circuit the --print-multi-lib option
ORIGINAL_ARGS=$(echo $* | sed -e 's,/cygdrive/\([a-zA-Z]\)/,\1:/,g')
CUSTOM=
if [ "x$1" = "xnios2-elf-gcc" ]
then
CUSTOM=" -O3 -g -Wall -mno-hw-div -mhw-mul -mno-hw-mulx -mgpopt=global -fno-math-errno -mcustom-fabss=224 -mcustom-fadds=253 -mcustom-fcmpeqs=227 -mcustom-fcmpges=228 -mcustom-fcmpgts=229 -mcustom-fcmples=230 -mcustom-fcmplts=231 -mcustom-fcmpnes=226 -mcustom-fdivs=255 -mcustom-fixsi=249 -mcustom-floatis=250 -mcustom-fmuls=252 -mcustom-fnegs=225 -mcustom-fsubs=254 "
fi
while [ $# -gt 0 ]
do
case "$1" in
--print-multi-lib)
echo ".;"
exit 0
esac
shift
done
eval $ORIGINAL_ARGS $CUSTOMerror log :[my private path]/newlib-build-tmp/build-newlib-stage-wrapper: line 23: nios2-elf-cc: command not foundit shows that the suffix is missing in build-newlib-stage-wrapper, when use command "STAGE_WRAPPER {cmd}"but if I change the var ORIGINAL_ARGS and add suffix ".exe" in file "nios2-newlib-gen"##add suffix for WSLuname=$(uname -r)uname=$(echo ${uname} | tr 'A-Z' 'a-z')if [[ "${uname}" =~ "microsoft" ]]thencat >>"$STAGE_WRAPPER" <<"EOF"echo "ORIGINAL_ARGS = ${ORIGINAL_ARGS}"#ORIGINAL_ARGS=$(echo ${ORIGINAL_ARGS} | sed -e "s,-B, -B,g")#ORIGINAL_ARGS=$(echo ${ORIGINAL_ARGS} | sed -e "s,-i, -i,g")#ORIGINAL_ARGS=$(echo ${ORIGINAL_ARGS} | sed -e "s,^nios2-elf-cc,nios2-elf-gcc,g")echo "ORIGINAL_ARGS = ${ORIGINAL_ARGS}"cmd=$(echo $ORIGINAL_ARGS | awk 'NR==1{print $1}')echo "cmd = $cmd"ORIGINAL_ARGS=$(echo ${ORIGINAL_ARGS} | sed -e "s,^$cmd,$cmd.exe,g")
EOFfiit still not work. in newlib tmporary config.log shows that it still not add suffix .exe when configure call nios2-elf-gccSo, it is complicated to fix script bugs to compile newlib in wsl by using mingw32 tool chain because newlib configure not add suffix for command even throught add suffix in STAGE_WRAPPER file!I doubt! Why Quartus not just migrate tool chain for linux platform and just remove mingw32 tool chain which has annoying suffix ".exe" because of using WSL , nearly a real linux enviroment!!!!!So, I copy tool chain "H-x86_64-pc-linux-gnu" from linux platformand edit "niso2_command_shell.sh" like this:# if grep -q Microsoft /proc/version; thenif [ -d "${SOPC_KIT_NIOS2}/bin/gnu/H-x86_64-mingw32/bin" ]; thenenv_var_prepend ${SOPC_KIT_NIOS2}/bin/gnu/H-x86_64-mingw32/binelseenv_var_prepend ${SOPC_KIT_NIOS2}/bin/gnu/H-i686-mingw32/binfi# elseif [ -d "${SOPC_KIT_NIOS2}/bin/gnu/H-x86_64-pc-linux-gnu/bin" ]; thenenv_var_prepend ${SOPC_KIT_NIOS2}/bin/gnu/H-x86_64-pc-linux-gnu/binelseenv_var_prepend ${SOPC_KIT_NIOS2}/bin/gnu/H-i686-pc-linux-gnu/binfi# ficomment if-else-ifand doses not need edit any thing in "nios2-newlib-gen"Be brief:there are two methods to solve these issues caused by wsl enviroment:1. just use nios2eds with Qurtus 18.1 pro, which use cygwin shell enviroment, works perfect on windows platform.2. copy tool chain "H-x86_64-pc-linux-gnu" form linux version's Quartus Pro to directory "niso2eds/bin/gnu/", so in makefile, use tool chain "H-x86_64-mingw32" and when compile newlib, use "H-x86_64-pc-linux-gnu" by itself.[Advice]:it is too complicated to use var WINDOWS_EXE,If you really want try WSL or WLS2, WHY NOT JUST MINGRATE LINUX TOOL CHAIN AND ERVERY RELATED SCRIPT to WSL enviroment and DISCARD "H-x86_64-mingw32" TOOL CHAIN!!!!!!!!ORrollback to use cygwin!these issues had been existed for three years since you discarded cygwin and started to use WSL. CAN ANYBODY FIX IT ?
