Michael2021's avatar
Michael2021
1 year ago
Can the .jic file, which is an FPGA configuration file, include the on-chip memory file of nios ii ?
Hello
If I specify the contents (.hex) of the on-chip memory of my Nios II embedded processor design,
compile it through Quartus Prime Pro, and use convert programming to create a .jic file,
will the on-chip memory contents also be loaded into the .jic file?
So, can I just load the jic file into external flash memory via a download cable?
Thank you
Michael
  • FvM's avatar
    FvM
    Nios .hex image must be compiled into memory initialization, then it becomes part of configuration bit stream and is loaded with .jic or JTAG configuration.
  • Hi @Michael2021,
    Good to know that it is working now, with no further clarification on this thread, it will be transitioned to community support for further help on doubts in this thread.
    Please login to ‘ https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
    Thank you for the questions and as always pleasure having you here.
    Best Wishes
    BB
