21 years agoCan the fpga read/write EPCS?
EPCS is directly connetcted to Cyclone. Can the fpga read/write EPCS after configuration? thanks
21 years agoThe EPCS controller peripheral talks to the EPCS device via the dedicated pins; the EPCS device should be connected to the FPGA with these dedicated pins. The literature mentioned in the post above tells you how to use the controller to access EPCS in your Nios II software.
