20 years agocan run the example hello.exe
according to the doc released from this forum. I make a hello.exe
the sourece files are copied from "C:\altera\kits\nios2\examples\software\linux\apps\samples\hello" and I change the topdir form .. to ./ everything runs well till I transport the hello.exe to /var dir in the uClinux it says"./hello.exe ./hello.exe: cannot execute" but when I copy hello.exe to my filesystem prj and paste it under /bin dir and upload the filesystem after I rebuild the filesystem . when I login in uClinux. I type hello .the program runs well. what is the difference between the tow method? btw:I transport the hello.exe as follow 1,transport the hello.exe to a ftp sever ,and put the file under /home/wch 2,in uClinx I type the follow cmd"mount -n nolock 192.168.1.124/home/wch /mnt -n 3,copy the hello.exe to /var since it is the only rw dir. 4 cd /var 5 type ./hello.exe it says "./hello.exe ./hello.exe: cannot execute"2 Replies
I am having the same problem as well. I transfer a sample hello world application to the NIOS II uCLinux via FTP into the tmp directory. I then atttemp to run it ./test and I get:
./test: cannot execute Why can I not run an executable from the Ram Disk? Did I miss something in the WIKI or the Forum? Thanks in advance. - Altera_Forum
maybe you do not have the "right" the execute the program. Please check the file attributes. You can change the file attributes with the command chmod.
