19 years agoCan not do TryOutuClinux!
Hi, This days, I am trying to resolve the problem about running the uClinux in Altera Nios dev board, mentioned in my last post, so many methods I've tried, even followed the steps in TryO...
19 years ago<div class='quotetop'>QUOTE </div>
--- Quote Start --- Which Altera Dev board do you use?[/b] --- Quote End --- The dev board is Nios Development Board, Stratix Edition, with A Stratix EP1S10F780C6 device, 8 Mbytes of flash memory, 1 Mbyte of static RAM, 16 Mbytes of SDRAM. <div class='quotetop'>QUOTE </div> --- Quote Start --- Did you config FPGA sof before download program , as Helmchen said?[/b] --- Quote End --- Of course, first of all, I download the standard .sof file to config FPGA, and then do the procedure: nios2-download -g zImage_std_1s10 this is OK! nios2-terminal the error comes!
