13 years agoCan I use the Nios II Eclipse S/W Debugger if I don't have the quartus project?
I have working Nios S/W and a .elf file (and my source code). And I have a working FPGA. The H/W designers developed the FPGA under Linux, in a completely different environment. I wrote my N...
13 years agoThe direct GDB part is easy; see the nios2-gdb-server example in Chapter 4 of the "Embedded Design Handbook" (page 4-11 of the current PDF on the website).
As far as eclipse goes, assuming you're using SDK generated makefiles for APP/BSP, I do something like this: - start eclipse with a blank workspace (no other projects in it) - File->Import->NIOS II ... -> Import custom makefile for NIOS...... - navigate to the BSP directory - give the new project a name name - finish the dialogs - repeat the Import... this time for the APP directory After that you can rebuild the software and download through the GUI. If you're not using NIOS SDK makefiles / normal build procedure, this wouldn't work.
