21 years agocan I use HAL when the project is linux project?
I need run linux on nios board to use the file system, thus the program project is linux project. The question is whether I am able to manipulate the timer in the nios2 system and how. I can use HAL in Altera NiosII project, but I donnot know how to use the timer in linux project.
The other question is how to generate the position dependent code for the linux project. I didnot find some documents about the memory mapping in the uClinux for nios2. Thanks!1 Reply
See:
timer example (http://www.niosforum.com/forum/index.php?act=st&f=18&t=710&hl=timer)
