20 years agoCan I update and save file when n2linux running?
hi all: I want to update some files( for example: rework the prime IP setting in `etc/inittab) when the nios2 uclinux is running. Then reset the DVB, the uclinux will confing the sy...
20 years agoyou should not set root=/dev/mtdblock0 at this time. you need to let jffs2 work first.
check if the drivers/mtd/maps/altera.c have the correct map for your board. check the info of mtd from /sys/block . try write and read from the mtd device, eg use "dd" . if the mtd is erased, jffs2 will format it. or you can make jffs2 image .
