20 years agoCan I update and save file when n2linux running?
hi all: I want to update some files( for example: rework the prime IP setting in `etc/inittab) when the nios2 uclinux is running. Then reset the DVB, the uclinux will confing the sy...
20 years ago --- Quote Start --- originally posted by hippo@Jul 27 2006, 09:57 AM you may try jffs2 on cfi flash or epcs.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=17195)
--- quote end ---
--- Quote End --- Thanks reply. Can you give me some hint to help me try jffs2 on cfi flash? I want to use the kernel version is 2.6.x .I can't open the web Check the very nice guide from Jdhar, http://via.dynalias.org/svn/uclinux/doc/trunk/epcs-ug.pdf (http://via.dynalias.org/svn/uclinux/doc/trunk/epcs-ug.pdf) who can post the pdf to me use email ? Thanks a lot.
