21 years ago
Can I step the assembly code in IDE?
I only know how to step the source code when debugging using IDE. Can I step the assembly code in IDE like GDB(insight)?
I know how to use GDB+insight to debug application of Altera NiosII project. Can I use GDB+insight to debug linux application? If yes, how to do that?
Thanks!!
    Yes you can step through the assembly code. There is a button to switch the view over to the assembled code. I'd point you to the button but I don't have the software installed on this computer. You can also see the memory contents, registers, etc....
    Cheers
    hello upstairs,
    Button ? what Button. I found that some assembled code that can't debug.
    Ok, then coming soon.
    In the version of the IDE I have (which has the button I refer to), assembly debug is possible.
    --- Quote Start ---
    originally posted by badomen@Dec 13 2004, 03:07 AM
    ok, then coming soon.
    in the version of the ide i have (which has the button i refer to), assembly debug is possible.
    --- Quote End ---
    The version 1.0.0 has the button?
    the button you're looking for is available when in the debug perspective. It is located in the right-most set of buttons on the debug control toolbar in the Debug window (where the resume/terminate/step buttons are). It's the 4th icon from the right, next to the 'show gdb console' icon. This should be available in all versions of the IDE.
    ..forgot to add - it's labelled 'Disassembly on/off'.
    --- Quote Start ---
    originally posted by dayne@Dec 13 2004, 08:54 AM
    the button you're looking for is available when in the debug perspective. it is located in the right-most set of buttons on the debug control toolbar in the debug window (where the resume/terminate/step buttons are). it's the 4th icon from the right, next to the 'show gdb console' icon. this should be available in all versions of the ide.
    --- Quote End ---
    I got it!
    Thanks so much!!
    Cheers,
    I was about to give more info since I have the IDE up in front of me. See ffone13 I'm not crazy lol
    Hi all,
    Can you step into these functions like:IORD_8DIRECT(),IOWR_8DIRECT() and so on?
    thank u.
    IORD and IOWR are macros (the IORD_xDIRECT family are all macros too).
    So you can't step into them because they appear inline (and normally compile up into exactly one instruction each in optimised code.
