22 years agocan I perform file operation using HAL
can I perform ANSI-C format file operations, such as fopen(), fscan(), fread(), using HAL instead of using OS file system ? thx!
22 years agoHi Cloud
Don't exactly know what you mean <div class='quotetop'>QUOTE </div> --- Quote Start --- Can I use SDK to achieve all the functions of IDE, such as puting operating system on the board, build a file in flash disk, compiling using newlib, etc? I prefer SKD[/b] --- Quote End --- I use the IDE to make my filesystem and burn it to flash. But you can ofcourse also do all these things from your command prompt(SOPC builder/cygwin). Here you can use the nios2-elf-xxx tools for just about everything. These are the tools that the IDE uses I think(no veteran at this) Regards GreateWhite.DK
