21 years agoCan I open a file for reading thru the JTAG link?
Hi all, For a test I want to download the content of a file onto RAM. Is it possible? If yes, what file path should I use? Regards, Kwok
21 years ago<div class='quotetop'>QUOTE </div>
--- Quote Start --- We are using cyclone device, but I don't know if we use the compress config generation (I'm not a HW engineer).[/b] --- Quote End --- It is an option during configuration file generation. You can select in the Quartus design environment. The file is approx 1/3 of the original (but I think it depends highly on the content of the logic). Normally this file comes as a IntelHex, but you can select raw binary also. I don't know if the IntelHex format has a checksum in the file format, this could also be handy. Stefaan
