21 years agoCan I open a file for reading thru the JTAG link?
Hi all, For a test I want to download the content of a file onto RAM. Is it possible? If yes, what file path should I use? Regards, Kwok
21 years agoMaybe simplest solution is using a standard uart. Ok it is slow, but maybe ok just for some tests.
Are you using the compress option on the config file generation (cyclone?)? Stefaan
