21 years agoCan’t find Nios2config.
I just downloaded eCos 2.0 for Nios II. After running the install, I am unable to find the nios2configtool utility. The configtool and configtool20 utilities are in the C:\altera\kits\nios2\component...
21 years agoHi niosIIuser,
That is my whole problem. The nios2configtool script does not seem to be installed. It's not a big problem since I was able to get a library to compile by starting the config tool manually, and udjusting the ptf file manually. I was merely wondering why i could not find the nios2configtool from the command prompt. The PATH variable seems to include all the eCos directories. Do I need to upload a eCos kernel, like I have to do with uClinux or do I simply upload the hello ELF file? [for the first example] Will eCos 2.0 work with a time limited Nios II processor.? I.E. will it load the right _time_limited.sof file?
