21 years agoCalling Assembly Function from C in NIOSII IDE
Has anyone called assemby functions from C with NIOS II IDE. I have an Assemby file that looks similar to the following; .global read_com1
read_com1:
movi...
21 years agoyancharles,
After somemore work you are correct. You would have to re-write your code for the NIOSII. The instruction set is quite different and NIOSII will not compile first generations NIOS. I hope that I did not miss lead you too bad, in my last comment. I had to re-write all of my legacy assmebly code to work with NIOSII (What a pain) Good Luck, Btaylor
