20 years agocal_uart(with fifo) + NIOSserial.c
As we know, we need uart with fifo to enchance the performance. So we got the cal_uart from Altera, which should tested by ourselves because it is not provided officially by altera. Now we use...
20 years agoDear smalllight,
I actually did not make any testing C file. All I did was a cat /dev/ttyS0 (set to 115200 bauds with stty). Then with minicom on my computer, I send about 5k of data (copy/paste in the minicom teminal). With that test it crashes quite fast. Another test was typing some charcters one by one in the terminal. I did not get anything in the cat /dev/ttyS0 until 64 chars were received (64 is the FIFO length). It works 3 or 4 times, then the system crashes. Thank you for taking some time for this. Best regards, Pierre-Olivier
