cache not enable
Thank you very much for your reply.I changed RUNTIME_CAL_REPORT to 1 according to your method,but I could not also calibrate SDRAM.The error message is consistent.I found that I didn't place the PLL reference clock pin in the address/command bank.Through the reference design I found that the PLL-ref-clock should be a differential clock,but I didn't connect the differential clock outside BANK 2K( address/command bank).Is this the reason twhy I can't calibrate DDR?In this case, what suggestions can be set to generate pll_ref_clk clock, so as to achieve the DDR3 read and write control.
I am also have the same problem with emif_reset message on Arria 10 U-boot with DDR4
I also changed RUNTIME_CAL_REPORT to 1, and i dont see debug printing.
did you managed to get the debug printing on U-boot?
can you advice?
Thanks!
