21 years agocache issues
We've managed to get uClinux to run on the custom HW board we are testing, and have also established a 100bT connection to the board, done remote login off a LAN etc. Everything seems to be prog...
21 years ago<div class='quotetop'>QUOTE </div>
--- Quote Start --- I would imagine that the linux port & drivers already have taken care of this but one of the Microtronix guys can probably confirm it.[/b] --- Quote End --- confirmed. The port and drivers Microtronix provided have taken care of this. thosburke, regarding the problem you run into, I recommend making a simple hello world program work first on the new core, before trying uClinux. I have had similar problems many times, most were proven no-software problems. Using a standalone small program, you can check if the flash, sdram, etc can be accessed ... Regards, wentao Microtronix
