19 years agoC2H problem
I met a problem in using C2H acceleration. My chip is Altera's EP1c6q240.And my quartus project's compilation report show that the LE source is 66%. But I want to accelerate my some func...
19 years agoAre you trying to accelerate something that pulls in the CFI flash drivers? If you are looking to improve computational performance I would look for something else to accelerate besides flash accesses.
To debug this I would first switch to the software only implementation and make sure that compiles properly first. I just went to line 82 in that file and found a struct. Take a look at the C2H user guide and near the end you'll see what the tool doesn't support (pg 113/118) here: http://www.altera.com/literature/ug/ug_nio...2h_compiler.pdf (http://www.altera.com/literature/ug/ug_nios2_c2h_compiler.pdf) I hope that helps
