16 years agoc2h error at bitmap header declaration
Hi everyone,
I am trying to accelerate a function func_acc(). However i am getting an error during the c2h compilation. What puzzles me is that the error is triggered at the main() function, not even at the function where i am accelerating.The error is: ../mand_sw.c:112: PARSE ERROR, ../mand_sw.c line 112 column 20 ERROR: C2H:0: C2H ERROR: "d:/altera/90/nios2eds/components/altera_avalon_c_hardware_accelerator/lex_and_yacc/c2h_cparse.exe" "P:/work/altera_c2h/sw/mandelbrot_sw/Debug/obj/mand_sw.c2h_pre" And the code at line 112 is: BITMAPFILEHEADER header; /* Bitmap header */ The error message is hardly helpful. Anybody who knows what is wrong here? One more thing; the code compiles nicely in the software only implementation. Thanks!3 Replies
you should have a look at the lines before line 112, and the definition of BITMAPFILEHEADER. With those kind of errors, the compiler hardly ever indicates the correct line for the error.
The c2h compiler is weird. It throws error at printf coded before the data declaration finishes:
double xmax, xmin, ymax, ymin, dx, dy; printf ("C2h screams this is illegal"); /*Error occurs here*/ BITMAPFILEHEADER header; BITMAPINFOHEADER bmiHeader; - Altera_Forum
No, not really, the C standard (prior to C99) required all variable definitions to be at the start of a block.
This is actually a good idea - it makes them much easier to find.
