16 years agoC2H Compilation Error - Explicit Inclusion
I am currently attempting to performing C2H hardware acceleration of a computationally intensive processing algorithm, specifically Dynamic Time Warping or DTW, commonly used in speech and image proc...
16 years agoI'm not familiar with VHDL (I switched to verilog long ago and have never looked back :)). By the sounds of it the accelerated HDL happens to contain a previously declared module/name called "IO". Just in case there are old files being left behind one thing you could try is deleting all the generated HDL files and the /db directory for your project, and then regenerate to see if that will compile.
If that doesn't work then I would open the generated HDL file and search for "IO" in there to find out what is causing it to be used.
