16 years agoC to HW
I have been doing for months the c2h tutorial and results haven't been successful.
Sooo...If I want to do the same thing as the tutorial (c2h) with a program I created what should I do? HELP! :eek:4 Replies
Then you should read the tutorial again, and again until you understand it.
I needed to read some of the Altera docs four times before I could understand them. - Altera_Forum
Could you be more specific and tell me which Altera docs helped you?
Because for me the tutorial skips steps which are needed to get the right results, or assumes the user knows when we don't know. - Altera_Forum
--- Quote Start --- Then you should read the tutorial again, and again until you understand it. I needed to read some of the Altera docs four times before I could understand them. --- Quote End --- Hi! I need to generate a sine wave from the Nios II core to compare it with a VHDL code of a triangular wave to produce a PWM. I had produced a VHDL code for a sine wave using a look up table.Do I just need to write a simple C code with a sine function? How can this C code be used to be compared and communicate with my triangular wave VHDL code? - Altera_Forum
You can still use a lookup table for this. C2H accelerators can access memory just like a processor does. If you stuff the results into a FIFO and clock the data out of it at a regular rate then you should get a nice set of sine samples from it.
