17 years agoC++ on uClinux on Nios II ?
Can you use C++ on uClinux on Nios II? I tried building the C++ test application available in menuconfig, but STL doesn't build: Code: Do I need to install something else to get pthread support...
17 years agoI would suggest MMU enabled Linux if you want to try C++ and pthread.
http://www.nioswiki.com/linux - Hippo
