17 years agoC++ on uClinux on Nios II ?
Can you use C++ on uClinux on Nios II? I tried building the C++ test application available in menuconfig, but STL doesn't build: Code: Do I need to install something else to get pthread support...
17 years agomake: Entering directory `/data/nios/nios2-linux/uClinux-dist/lib/STLport/build/lib'
nios2-linux-uclibc-g++ -pthread -fexceptions -fident -fPIC -O2 -fuse-cxa-atexit -D_STLP_REAL_LOCALE_IMPLEMENTED -D_GNU_SOURCE -I/data/nios/nios2-linux/uClinux-dist/include/STLport -I/data/nios/nios2-linux/uClinux-dist/include -c -o obj/gcc/shared/dll_main.o ../../src/dll_main.cpp The C++ is supported on nios2. But I build the applicaiotn without the menuconfig, I build the applicaiotn with my Makefile. I have build the MiniGUI and C++ applicaiotn. -pthread or -lpthread ???
