9 years agoc++ class memory consumption
Hello, I am trying to code with cpp and now i started a blank project with a NIOS II/f processor, connected to 16KB onchip RAM, created with QSYS in the NIOS II IDE. I took the generated .sop...
9 years agoHello,
I am stuck at the compiler options. Where can i set them in the NIOS SBT IDE? This is just to test, if I can use c++ the way I'd like to. I have a project, momentary written in C which contains a few functions which manage UART communication, CAN communication, writing into the internal flash of the fpga and so on and i thought about rewritting the code in c++ because i like the idea about creating classes and defining objects. I would probably be able to write the code without any need for a custom destructor, but just in case I want to be able to use it without the massive memory allocation which occurs at the moment.
