21 years agoC++ Application
I was hoping someone out there is using Standard C++ on the Nios II. I can compile, link, and add to the filesystem the following code: # include <stdio.h> // hello_nios.cpp int main(int argc...
21 years agouClibc has supported libstdc++since v0.9.11, and I've used it without problem under m68k uClinux.
EDIT: Perhaps I should've clarified.... you have to re-build libstdc++ against uClibc yourself. It's not difficult. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif Also, some quick googling turned up another alternative as well: http://cxx.uclibc.org/ (http://cxx.uclibc.org/) which is a small libstdc++ replacement. (incomplete, but seems to be together enough for the basics, like streams) I'll actually probably end up building libstdc++ for nios-II soon myself, so I'll let you know if there's any caveats.
