Byte Blaster for USB Portss?
Hello, i need everybody helps here.....current production of LAptops does not have parallel port with it.........is there any options to use byteblaster ?
How about if i get a usb to parallel port cable....does it work? Any suggestions from you guys ? my humble thanks to you all. regards wayne3 Replies
I don't think I have ever heard of a USB --> Parallel adapter (sorry for the bad news). Do you have the ability to pencil in some USB blasters into your budget since you'll be able to connect them directly?
I have seen some USB to parallel port adapters. I wonder if one of these would work?
http://www.buy.com/retail/product.asp?sku=...d=0&dcaid=17379 (http://www.buy.com/retail/product.asp?sku=10339356&searchengine=froogle&searchterm=10339356&type=pe&category=comp&gad=0&dcaid=17379) - Altera_Forum
I have a USB hub with parallel port, but I have only ever got it to work with a printer. I suspect that the problem is that most widgets, such as a Byteblaster, access the port diectly and so cannot be automatically re-directed throught the USB interface to a remote port. Windows can however re-direct printing to a specially written driver provided by the USB hub manufaturer.
