22 years agoBusyBox use
I tried to use BusyBox package but I got the following ouput
uClinux/Nios II Altera Nios II support © 2004 Microtronix Datacom Ltd. On node 0 totalpages: 4096 DMA zone: 0 pages, LIFO batch:1 Normal zone: 4096 pages, LIFO batch:1 HighMem zone: 0 pages, LIFO batch:1 Built 1 zonelists Kernel command line: root=/dev/mtdblock0 ro PID hash table entries: 16 (order 4: 128 bytes) Memory available: 14512k/4096k RAM, 0k/0k ROM (1365k kernel code, 303k data) Calibrating delay loop... 39.83 BogoMIPS Dentry cache hash table entries: 2048 (order: 1, 8192 bytes) Inode-cache hash table entries: 1024 (order: 0, 4096 bytes) Mount-cache hash table entries: 512 (order: 0, 4096 bytes) POSIX conformance testing by UNIFIX NET: Registered protocol family 16 Serial: JTAG UART driver : 1.3 $ ttyJ0 at MMIO 0x80920820 (irq = 1) is a jtag_uart RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize smc_probe: 80000 Khz Nios SMSC LAN91C111 Driver (v2.1), (Linux Kernel 2.6) eth0: SMC91C11xFD(rev:1) at 0x80910300 IRQ:6 MEMSIZE:8192b NOWAIT:0 ADDR: 00:07:ed:0c:02:16 smc_probe: 80000 Khz Nios Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2 ide: Assuming 50MHz system bus speed for PIO modes; override with idebus=xx CF: ctl=2 Using anticipatory io scheduler microtronix[mtd]: RAM probe address=0x200000 size=0x1bc000 Creating 1 MTD partitions on "RAM": 0x00000000-0x001bc000 : "ROMfs" microtronix[mtd]: set ROMfs to be root filesystem NET: Registered protocol family 2 IP: routing cache hash table of 512 buckets, 4Kbytes TCP: Hash tables configured (established 1024 bind 2048) NET: Registered protocol family 1 NET: Registered protocol family 17 VFS: Mounted root (romfs filesystem) readonly. Freeing unused kernel memory: 48k freed (0x1186000 - 0x1191000) expand: from=/ramfs.img to=/dev/ram0 expand: from=/ramfs.img to=/dev/ram1 init: exec failed init: exec failed Is there any recommandation to implement it ? I am using the 1S40 Linux reference design.No RepliesBe the first to reply
