20 years ago
busybox problem
i have a lot of errors when i compile busybox(ver:1.0.0,1.1.0,1.1.2,1.1.3) with crosscompiler is a nios2-linux-uclibc. why so? errors in files applets.c and other. with standart gcc - allright!!!
    --- Quote Start ---
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=16466)
    --- quote end ---
    --- Quote End ---
    Busybox, config for cross compile
    ##  Build Options#
    CONFIG_STATIC=y#  CONFIG_BUILD_LIBBUSYBOX is not set#  CONFIG_FEATURE_FULL_LIBBUSYBOX is not set#  CONFIG_FEATURE_SHARED_BUSYBOX is not set
    CONFIG_LFS=y
    USING_CROSS_COMPILER=y
    CROSS_COMPILER_PREFIX="nios2-linux-uclibc-"
    EXTRA_CFLAGS_OPTIONS="-Dfork=vfork -Ddaemon=clone"#  CONFIG_BUILD_AT_ONCE is not set
    # #  Installation Options# #  CONFIG_INSTALL_NO_USR is not set
    CONFIG_INSTALL_APPLET_SYMLINKS=y#  CONFIG_INSTALL_APPLET_HARDLINKS is not set#  CONFIG_INSTALL_APPLET_DONT is not set
    PREFIX="/home/hippo/rootfs"
    I used this flags before, (but not now)
    EXTRA_CFLAGS_OPTIONS="-D__uClinux__ -Dfork=vfork"
    Busybox, Makefile add elf2flt flag
    busybox_unstripped: .depend $(LIBBUSYBOX_SONAME) $(BUSYBOX_SRC) $(libraries-y)
        $(do_link) $(PROG_CFLAGS) $(PROG_LDFLAGS) $(CFLAGS_COMBINE)
        -Wl,-elf2flt="-s 16000" -Wl,-v -Wl,-d
        -o $@ -Wl,--start-group
        $(APPLETS_DEFINE) $(APPLET_SRC)
        $(BUSYBOX_DEFINE) $(BUSYBOX_SRC) $(libraries-y)
        $(LDBUSYBOX) $(LIBRARIES)
        -Wl,--end-group
    busybox: busybox_unstripped
        $(Q)cp busybox_unstripped busybox#     $(do_strip)
    There is an important issue about busybox. It takes more memory on MMU-less arch.
    So I moved away from busybox a little. I use stand alone init, sash, and servers. I built others utils into busybox. see http://nioswiki.jot.com/wikihome/operating...nux/uclinuxdist (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/uclinuxdist)
    I all so and did, on manual, has corrected the necessary files, it is correct configured busybox, but errors when compiling there is.
    stand alone init, sash too give the errors when compiling that to do?
    --- Quote Start ---
    originally posted by realsystem@Jun 29 2006, 04:45 PM
    i all so and did, on manual, has corrected the necessary files, it is correct configured busybox, but errors when compiling there is.
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=16514)
    --- quote end ---
    --- Quote End ---
    Please give your error message.
