21 years agobusybox problem
Did somebody meet the problem in busybox building? When I "make" the busybox after "make menuconfig", the error message was showed as below: libbb/loop.c:32:27: linux/version.h: No such f...
21 years agoHi, busybox requires the kernel header files in order to compile correctly. We've provided an option within the busybox configuration utility to point to the correct kernel build.
Take a look at page 30 within the Reference Guide for more information (if you're using release 1.3 of the Nios II Linux distribution which is now available).
