21 years agobusybox error
when i built busybox according <linux referece guide>, everythings gone well
except when linux startup, the error comes: <div class='quotetop'>QUOTE </div> --- Quote Start --- Creating 4 MTD partitions on "Altera NDK flash (AMD)": 0x00200000-0x00600000 : "romfs/jffs2" 0x00000000-0x00200000 : "loader/kernel" 0x00600000-0x00700000 : "User configuration" 0x00700000-0x00800000 : "safe configuration" i2c /dev entries driver i2c-oc: i2c Opencores adapter driver Opencores i2c algorithm module NET: Registered protocol family 2 IP: routing cache hash table of 512 buckets, 4Kbytes TCP established hash table entries: 1024 (order: 1, 8192 bytes) TCP bind hash table entries: 1024 (order: 0, 4096 bytes) TCP: Hash tables configured (established 1024 bind 1024) NET: Registered protocol family 1 NET: Registered protocol family 17 VFS: Mounted root (romfs filesystem) readonly. Freeing unused kernel memory: 60k freed (0x116e000 - 0x117c000) Kernel panic - not syncing: No init found. Try passing init= option to kernel.[/b] --- Quote End --- I guess it is because of no init.lnk in /bin but in /sbin So I copy /sbin/init.lnk to /bin, but failed again,the same error occured. Can you help me?5 Replies
Euhm
I'm pretty much clueless as it comes to the latest incarnations of Windows, but a x.lnk file seems to be a link to a certain file. From what I remember (>5 yrs ago), a *.lnk file is a txt file with in it the txt where the file is linking to. I doubt that would be recognised by a Unix based system. - Altera_Forum
I found the reason.
When I "make install", "busybox" copied to <project>/target, but it was rw only not excutable. So I "mv busybox busybox.exe" (chmod 777 in cygwin was useless during my test). Then "build fs" , upload, it worked. PS: my classmates' work is "xrw" of "busybox" after "make install", so I don't know why things goes wrong in my way. - Altera_Forum
Hi
I have sthe same problem with the basic kernel and filesystem project. I just go through the quick start guide but get the same output you've pasted. I don't find anything under the filesystem/target that I should make executable. Any idea on what can go wrong when I just want to get a login to uClinux ? Nir - Altera_Forum
What's your error message?
Hi
It was my dumb mistake, sorry. Nir
