20 years agobuilt program in nios2 IDE 5.0
Hi all:
I make ncurses 5.5 and cdk source code by RED HAT LINUX 8.0. After make I got the include files and the interrelated libcdk.a , libncurses.a .Then I edit my application program use Microtronix Nios II LINUX Application Project module in nios2 IDE 5.0. My source code as follows: # include "cdkscreen.h" int main(void) { initCDKColor(); return 0; } My makefile as follows: # # configurable options# - set DEBUG = 1 to turn on debugging support# DEBUG = 1 PROJ_NAME = testcdkc LIBNETDIR := cdk_lib INSTALL_DIR = PROGS := $(PROJ_NAME).exe CFLAGS += # # You should not need to modify anything beyond this point# include Rules.mak ifeq '$(DEBUG)' '1' PROGS += $(PROGS:.exe=.gdb) endif CFLAGS += -I include -I ncurses_include -I$(LIBNETDIR) LDLIBS += $(LIBNETDIR)/libncurses.a $(LIBNETDIR)/libcdk.a all: $(PROGS) .PHONY: clean clean: -rm -f *.[oad] *.elf *.gdb *.bin *.exe .PHONY: install install: all ifeq "$(INSTALL_DIR)" "" $(error No installation directory specified) endif mkdir -p $(INSTALL_DIR)/bin install -v $(filter %.exe, $(PROGS)) $(INSTALL_DIR)/bin But I build the program fail. The fail information as follows: make -k all no emulation specific options. nios2-elf-gcc -nostdinc -D__linux__ -O0 -g -I"d:/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.uClibc_1.4.0"/include -I/cygdrive/d/altera/kits/nios2/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1//include -fno-optimize-sibling-calls -mhw-mul -mhw-mulx -I include -I ncurses_include -Icdk_lib -Wall -c -o testcdkc.o testcdkc.c nios2-elf-gcc -msys-crt0="d:/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.uClibc_1.4.0"/lib/crt0.o -r -d -L"d:/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.uClibc_1.4.0"/lib -o testcdkc.bin testcdkc.o /cygdrive/d/altera/kits/nios2/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/../../../../nios2-elf/lib/libm.a /cygdrive/d/altera/kits/nios2/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/libgcc.a "d:/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.uClibc_1.4.0"/lib/libc.a cdk_lib/libncurses.a cdk_lib/libcdk.a cdk_lib/libnet.a /cygdrive/d/altera/kits/nios2/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/../../../../nios2-elf/bin/ld: cdk_lib/libcdk.a(draw.o): Relocations in generic ELF (EM: 3) cdk_lib/libcdk.a: could not read symbols: File in wrong format collect2: ld returned 1 exit status make: *** [testcdkc.bin] Error 1 make: Target `all' not remade because of errors. rm testcdkc.o I think the reason of my failure is cygwin/bin/../lib/gcc/nios2-elf/3.4.1/../../../../nios2-elf/bin/ld: cdk_lib/libcdk.a(draw.o): Relocations in generic ELF (EM: 3) cdk_lib/libcdk.a: could not read symbols: File in wrong format collect2: ld returned 1 exit status make: *** [testcdkc.bin] Error 1 Who can tell me resolvent? I think it cause to libcdk.a through RAD HAT LINUCX turn into, it is fail to compile to lead to the fact. Thanks a lot5 Replies
up
--- Quote Start --- originally posted by alex824@Nov 10 2005, 09:50 PM hi all:i make ncurses 5.5 and cdk source code by red hat linux 8.0. after make i got
the include files and the interrelated libcdk.a , libncurses.a .then i edit my
application program use microtronix nios ii linux application project module in
nios2 ide 5.0.
[...] --- Quote End --- It looks like you compiled i386(intel) binaries with your RedHat machine. You need to crosscompile ncurses for the nios2 platform in order to use the libraries on your nios2 system. The fact that you get: "could not read symbols: File in wrong format" Is most likely because it's a i386 lib and not a nios2 lib.
--- Quote End --- It looks like you compiled i386(intel) binaries with your RedHat machine. You need to crosscompile ncurses for the nios2 platform in order to use the libraries on your nios2 system. The fact that you get: "could not read symbols: File in wrong format" Is most likely because it's a i386 lib and not a nios2 lib. <div align='right'><{post_snapback}> (index.php?act=findpost&pid=10966)</div> --- Quote End --- Hi wqossens, thanks for you reply. I think you are right. But I dont't know how to rework the ncurses configure file. In the nios sdk shell, I type ./configure to crosscompile ncurses. but fail. The error information as follow: egrep: not found egrep: not found egrep: not found Configuring NCURSES . ABI <Tue Nov 15 10:18:48 2005> configure: error: Release major-version value is empty What can I do?Should I must use microtronix Nios II Cross Development Kit to crosscompile the whole GNU opensource code? - Altera_Forum
--- Quote Start --- originally posted by alex824@Nov 14 2005, 09:31 PM what can i do?should i must use microtronix nios ii cross development kit tocrosscompile the whole gnu opensource code?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=10973)
--- quote end ---
--- Quote End --- Since you have a RedHat machine I'd recommend you using the crosscompiler as shown discussed in the this (http://www.niosforum.com/forum/index.php?showtopic=2007#) thread which links to marc's crosscompiler (http://scorpius.homelinux.org/~marc/nios2.html) which I use for all my crosscompiling. You can configure with ./configure --target=nios2-linux but you (probably) have to add "nios2" to the list of machines in the config.sub file in the section starting with: case $basic_machine in: Or something like that. I'm currently on Windows so I'm afraid I can't check. Hope this helps.
Hi wqoossens ,thanks for you reply.
I will try my best effort till success.
