20 years agoBuildroot help
I'm following the hippo's bullroot and when I tried to compile the kernel this is what I got:$ make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- menuconfig
no emulation specific options.
scripts/kconfig/mconf arch/nios2nommu/Kconfig# # using defaults found in .config#
*** End of Linux kernel configuration.
*** Execute 'make' to build the kernel or try 'make help'.
$ make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- zImage
CHK include/linux/version.h
SPLIT include/linux/autoconf.h -> include/config/*
CHK include/nios2_system.h
perl -I/home/MFM/linux-2.6.x/arch/nios2nommu/scripts /home/MFM/linux-2.6.x/arch/nios2nommu/scripts/gen_nios2_system.h.pl cpu sdram ext_flash < std_1s40.ptf > include/nios2_system.h.tmp; if && cmp -s include/nios2_system.h include/nios2_system.h.tmp; then rm -f include/nios2_system.h.tmp; else echo ' UPD include/nios2_system.h'; mv -f include/nios2_system.h.tmp include/nios2_system.h; fi
make: `arch/nios2nommu/kernel/asm-offsets.s' is up to date.
CHK include/asm-nios2nommu/asm-offsets.h
CHK include/linux/compile.h
CHK usr/initramfs_list
CC drivers/ide/ide.o
drivers/ide/ide.c: In function `init_hwif_default':
drivers/ide/ide.c:262: error: `na_ide_ide' undeclared (first use in this function)
drivers/ide/ide.c:262: error: (Each undeclared identifier is reported only once
drivers/ide/ide.c:262: error: for each function it appears in.)
drivers/ide/ide.c: In function `init_ide_data':
drivers/ide/ide.c:313: error: `na_ide_ide_irq' undeclared (first use in this function)
make: *** Error 1
make: *** Error 2
make: *** Error 2
$ P.S: I'm under FC5, my board is a Stratix Pro Edition 1S40 and I do need a CF support http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/wink.gif3 Replies
hi, MFM http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/tongue.gif
the following msg :
I think that it means one of two things : 1) there is no ruls to make (see option "include" in Makefile ) 2) or, the include specified is not adequate. wa allaho a3lam. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gifno emulation specific options. - Altera_Forum
The IDE error means that it can't find the CF IDE component in the PTF file. Did you use the correct PTF file, and do a make HWSELECT on it?
--- Quote Start --- originally posted by jdhar@May 7 2006, 12:29 AM the ide error means that it can't find the cf ide component in the ptf file. did you use the correct ptf file, and do a make hwselect on it?<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15133)
--- quote end ---
--- Quote End --- Hi jdhar, that's it, thanks a lot http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
