20 years agobuildroot fialed!Help!
Hi ,I follow Hippo 's instructions to build the buildroot. But it failed. The sourece codes i use are: buildroot-20060506.tar.bz2,busybox-20060506.tar.bz2, uClibc-20060506.tar.bz2,uClinux...
20 years ago --- Quote Start --- originally posted by xunios+may 9 2006, 09:38 am--><div class='quotetop'>quote (xunios @ may 9 2006, 09:38 am)</div>
--- quote start ---
<!--quotebegin-hippo@May 7 2006, 08:11 PM it seems lack some packages for config.
you must select "developement packages" during installation of fc4/5.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15162)
--- quote end ---
--- Quote End --- make menuconfig passed,,but failed in make.(after makemenuconfig,the /buildroot/build_nios2/busybox/ doesnot exist.) Here hte errors after make: /root/buildroot/toolchain_build_nios2/binutils-2.15/gas/config/tc-nios2.c: 在函 数 ‘md_convert_frag’ 中: /root/buildroot/toolchain_build_nios2/binutils-2.15/gas/config/tc-nios2.c:1338: 警告:初始化指针时目标与指针有/无符号不一致 /root/buildroot/toolchain_build_nios2/binutils-2.15/gas/config/tc-nios2.c:1356: 警告:传递参数 1 (属于 ‘md_number_to_chars’) 给指针时目标与指针有/无符号不一致 /root/buildroot/toolchain_build_nios2/binutils-2.15/gas/config/tc-nios2.c:1357: 警告:传递参数 1 (属于 ‘md_number_to_chars’) 给指针时目标与指针有/无符号不一致 /root/buildroot/toolchain_build_nios2/binutils-2.15/gas/config/tc-nios2.c:1358: 警告:传递参数 1 (属于 ‘md_number_to_chars’) 给指针时目标与指针有/无符号不一致 /root/buildroot/toolchain_build_nios2/binutils-2.15/gas/config/tc-nios2.c:1376: 警告:传递参数 1 (属于 ‘md_chars_to_number’) 给指针时目标与指针有/无符号不一致 /root/buildroot/toolchain_build_nios2/binutils-2.15/gas/config/tc-nios2.c:1405: 警告:传递参数 1 (属于 ‘md_number_to_chars’) 给指针时目标与指针有/无符号不一致 /root/buildroot/toolchain_build_nios2/binutils-2.15/gas/config/tc-nios2.c:1406: 警告:传递参数 1 (属于 ‘md_number_to_chars’) 给指针时目标与指针有/无符号不一致 /root/buildroot/toolchain_build_nios2/binutils-2.15/gas/config/tc-nios2.c:1407: 警告:传递参数 1 (属于 ‘md_number_to_chars’) 给指针时目标与指针有/无符号不一致 /root/buildroot/toolchain_build_nios2/binutils-2.15/gas/config/tc-nios2.c:1408: 警告:传递参数 1 (属于 ‘md_number_to_chars’) 给指针时目标与指针有/无符号不一致 /root/buildroot/toolchain_build_nios2/binutils-2.15/gas/config/tc-nios2.c: 在函 数 ‘md_apply_fix3’ 中: /root/buildroot/toolchain_build_nios2/binutils-2.15/gas/config/tc-nios2.c:1664: 错误:赋值运算中的左值无效 /root/buildroot/toolchain_build_nios2/binutils-2.15/gas/config/tc-nios2.c: 在函 数 ‘nios2_check_overflow’ 中: /root/buildroot/toolchain_build_nios2/binutils-2.15/gas/config/tc-nios2.c:1709: 错误:赋值运算中的左值无效 make[4]: *** [tc-nios2.o] 错误 1 make[4]: Leaving directory `/root/buildroot/toolchain_build_nios2/binutils-2.15-build/gas' make[3]: *** [all-recursive] 错误 1 make[3]: Leaving directory `/root/buildroot/toolchain_build_nios2/binutils-2.15-build/gas' make[2]: *** [all] 错误 2 make[2]: Leaving directory `/root/buildroot/toolchain_build_nios2/binutils-2.15-build/gas' make[1]: *** [all-gas] 错误 2 make[1]: Leaving directory `/root/buildroot/toolchain_build_nios2/binutils-2.15-build' make: *** [/root/buildroot/toolchain_build_nios2/binutils-2.15-build/binutils/objdump] 错误 2 <div align='right'><{post_snapback}> (index.php?act=findpost&pid=15205)</div> [/b] --- Quote End --- Did you install gcc-32 as I said in the buildroot guide? Check with "gcc -v" . The gcc4 can not compile binutils-2.15 . Please check the binary tools on Jhdar's site, (thanks a lot to his help) http://via.fps-tech.org/snapshots/nios2/ (http://via.fps-tech.org/snapshots/nios2/)
