20 years ago
buildroot failed
Hello all, http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
i followed the great thread ( http://forum.niosforum.com/forum/index.php?showtopic=3174 (http://forum.niosforum.com/forum/index.php?showtopic=3174) )
i downloaded fedora core 5
i installed " compat-gcc-32 " with yum ..and tested the gcc version ..
i downloaed all the files ..
i downloaded the attached files in that thread .. unzipped ..in the ~/download folder .. the build was replaced by the new one from the attachment :: the one having uClinux-dist-test-20051209.tar.bz2
then i executed it ..
it start extracting ..unzipping ..generating .. compiling .. this long story ..
stii it reached an error .. . i repeted the whole process several times.. same result ..
the error was this :
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
/tarek/buildroot/toolchain_build_nios2/gcc-3.4.6-final/nios2-linux-uclibc/libstdc++-v3/include -I/home/tarek/buildroot/toolchain_build_nios2/gcc-3.4.6/libstdc++-v3/libsupc++ -g -Os -g -Os -fno-implicit-templates -Wall -W -Wwrite-strings -Wcast-qual -fdiagnostics-show-location=once -ffunction-sections -fdata-sections -c /home/tarek/buildroot/toolchain_build_nios2/gcc-3.4.6/libstdc++-v3/libsupc++/eh_alloc.cc -fPIC -DPIC -o eh_alloc.o
/tmp/ccaOktFs.s: Assembler messages:
/tmp/ccaOktFs.s:741: Internal error!
Assertion failure in md_number_to_chars at /home/tarek/buildroot/toolchain_build_nios2/binutils-2.15/gas/config/tc-nios2.c line 1190.
Please report this bug.
make[4]: *** [eh_alloc.lo] Error 1
make[4]: Leaving directory `/home/tarek/buildroot/toolchain_build_nios2/gcc-3.4.6-final/nios2-linux-uclibc/libstdc++-v3/libsupc++&#39;
make[3]: *** [all-recursive] Error 1
make[3]: Leaving directory `/home/tarek/buildroot/toolchain_build_nios2/gcc-3.4.6-final/nios2-linux-uclibc/libstdc++-v3&#39;
make[2]: *** [all] Error 2
make[2]: Leaving directory `/home/tarek/buildroot/toolchain_build_nios2/gcc-3.4.6-final/nios2-linux-uclibc/libstdc++-v3&#39;
make[1]: *** [all-target-libstdc++-v3] Error 2
make[1]: Leaving directory `/home/tarek/buildroot/toolchain_build_nios2/gcc-3.4.6-final&#39;
make: *** [/home/tarek/buildroot/toolchain_build_nios2/gcc-3.4.6-final/.compiled] Error 2[/b]
--- Quote End ---
i tried to continue with the guide .. more errors showed up .. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/ohmy.gif
pls help http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/blink.gif
pleeeeeeeeease help http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/ohmy.gif
thanks in advance
