20 years agoBuilding uCLinux with no CFI flash
I'm trying to get uCLinux running on a Nios processor on a Cyclone II DSP dev board. (not the Cyclone II Nios dev board) I am using the uCLinuxDist from the wiki, running on Ubuntu in VMWare, an...
20 years agoYes, it did help. Thanks everyone.
I did know that this was what I was supposed to do, but I was running into a problem with SOPC Builder 6.0. In this version, you can create "board descriptions," which specify all the hardware on the board. The problem then, is that once a board description is chosen, it won't allow you to add components that aren't physically on the board, such as a CFI! So, under SOPC Builder 6.0, the board description needs to be set to 'Unassigned' to work well. So I have uCLinux up and running on a Cyclone II DSP dev board now.
