20 years agobuilding uClinux for Nios II problem, HELP!
Hi, All, I'm a new starter to Nios. I'm trying to build a kernel for my Nios II. I downloaded the snapshot (1/30/06 copy) and tried to compile on my FC3 PC(kernel 2.6.9 with gcc 3....
20 years ago --- Quote Start --- originally posted by bdu@Feb 3 2006, 12:12 PM hi, all,
i'm a new starter to nios. i'm trying to build a kernel for my nios ii.
i downloaded the snapshot (1/30/06 copy) and tried to compile on my fc3 pc(kernel 2.6.9 with gcc 3.4.2).
i did a "make menuconfig" and chose "nios2" as the processor and kept all other options as default. then i run "make" to compile the whole thing. i run this whole procedure as a normal user.
after a while, i go this error:
make[2]: leaving directory `/home/bdu/nios/buildroot/toolchain_build_nios2/uclibc/utils'
make[1]: leaving directory `/home/bdu/nios/buildroot/toolchain_build_nios2/uclibc'
mkdir -p /home/bdu/nios/buildroot/build_nios2/staging_dir/nios2-linux-uclibc/target_utils
install -c /home/bdu/nios/buildroot/build_nios2/root/usr/bin/ldd
/home/bdu/nios/buildroot/build_nios2/staging_dir/nios2-linux-uclibc/target_utils/ldd
install: cannot stat `/home/bdu/nios/buildroot/build_nios2/root/usr/bin/ldd': no such file or directory
make: *** [/home/bdu/nios/buildroot/build_nios2/root/usr/bin/ldd] error 1
i later tried to repeat this as root and still got this error. so please help me and tell me what did i miss or do wrong.
thanks for all the help!
-bo
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=12534)
--- quote end ---
--- Quote End --- Start with this thread - http://forum.niosforum.com/forum/index.php...wtopic=3174&hl= (http://forum.niosforum.com/forum/index.php?showtopic=3174&hl=)
