13 years agoBuilding static library with NIOS II Software Build Tools for Eclipse 13.0
Hello, I has started to work with the NIOS II Software Build Tools for Eclipse in version 13.0sp1 since two weeks. There I am going to build a static library. Therefore, I used the guidance of ...
12 years agoI realize this is an old post, but this might help others.
You need to call these command from the Nios II Command Shell: To clear the sources from the makefile:nios2-lib-update-makefile --lib-dir /path/to/your/lib --no-src To insert all source files in the folder to the makefile: nios2-lib-update-makefile --lib-dir /path/to/your/lib --add-src-rdir /path/to/your/sources You can read the NIOS-II manual for more info on this.
