13 years agoBuilding static library with NIOS II Software Build Tools for Eclipse 13.0
Hello, I has started to work with the NIOS II Software Build Tools for Eclipse in version 13.0sp1 since two weeks. There I am going to build a static library. Therefore, I used the guidance of ...
13 years agoHi
Im also having build problems in Nios2 SBT in both version 8.1 and 9.1. Below is the error message. Please help. Thank you **** Build of configuration Nios II for project test_bsp **** make all Compiling alt_alarm_start.c... nios2-elf-gcc -xc -MP -MMD -c -I./drivers/inc -I. -I./drivers/inc -I./HAL/inc -DSYSTEM_BUS_WIDTH=32 -D__hal__ -pipe -DALT_NO_INSTRUCTION_EMULATION -DALTERA_TRIPLE_SPEED_MAC -DALT_SINGLE_THREADED -DRO_ZIPFS -O0 -g -Wall -mhw-div -mhw-mul -mno-hw-mulx -o obj/HAL/src/alt_alarm_start.o c:/NIOS-Download/niosii-ethernet-standard-3c25/software/test_bsp/HAL/src/alt_alarm_start.c In file included from ./HAL/inc/sys/alt_alarm.h:42, from c:/NIOS-Download/niosii-ethernet-standard-3c25/software/test_bsp/HAL/src/alt_alarm_start.c:48: ./HAL/inc/sys/alt_llist.h:42:23: alt_types.h: No such file or directory In file included from ./HAL/inc/sys/alt_alarm.h:42, from c:/NIOS-Download/niosii-ethernet-standard-3c25/software/test_bsp/HAL/src/alt_alarm_start.c:48: ./HAL/inc/sys/alt_llist.h:90: error: syntax error before "void" ./HAL/inc/sys/alt_llist.h:92: warning: return type defaults to `int' ./HAL/inc/sys/alt_llist.h:105: error: syntax error before "void" ./HAL/inc/sys/alt_llist.h:106: warning: return type defaults to `int' In file included from ./HAL/inc/sys/alt_alarm.h:45, from c:/NIOS-Download/niosii-ethernet-standard-3c25/software/test_bsp/HAL/src/alt_alarm_start.c:48: ./HAL/inc/priv/alt_alarm.h:42:23: alt_types.h: No such file or directory In file included from ./HAL/inc/sys/alt_alarm.h:45, from c:/NIOS-Download/niosii-ethernet-standard-3c25/software/test_bsp/HAL/src/alt_alarm_start.c:48: ./HAL/inc/priv/alt_alarm.h:63: error: syntax error before "alt_u32" ./HAL/inc/priv/alt_alarm.h:63: warning: no semicolon at end of struct or union ./HAL/inc/priv/alt_alarm.h:64: error: syntax error before '*' token ./HAL/inc/priv/alt_alarm.h:64: warning: type defaults to `int' in declaration of `alt_u32' ./HAL/inc/priv/alt_alarm.h:64: error: `alt_u32' declared as function returning a function ./HAL/inc/priv/alt_alarm.h:64: warning: data definition has no type or storage class ./HAL/inc/priv/alt_alarm.h:69: error: syntax error before "rollover" ./HAL/inc/priv/alt_alarm.h:69: warning: type defaults to `int' in declaration of `rollover' ./HAL/inc/priv/alt_alarm.h:69: warning: data definition has no type or storage class ./HAL/inc/priv/alt_alarm.h:72: error: syntax error before '}' token ./HAL/inc/priv/alt_alarm.h:83: error: syntax error before "_alt_tick_rate" ./HAL/inc/priv/alt_alarm.h:83: warning: type defaults to `int' in declaration of `_alt_tick_rate' ./HAL/inc/priv/alt_alarm.h:83: warning: data definition has no type or storage class ./HAL/inc/priv/alt_alarm.h:91: error: syntax error before "_alt_nticks" ./HAL/inc/priv/alt_alarm.h:91: warning: type defaults to `int' in declaration of `_alt_nticks' ./HAL/inc/priv/alt_alarm.h:91: warning: data definition has no type or storage class In file included from c:/NIOS-Download/niosii-ethernet-standard-3c25/software/test_bsp/HAL/src/alt_alarm_start.c:48: ./HAL/inc/sys/alt_alarm.h:68: error: syntax error before "alt_u32" ./HAL/inc/sys/alt_alarm.h:69: error: `alt_alarm_start' declared as function returning a function ./HAL/inc/sys/alt_alarm.h:70: error: syntax error before "void" ./HAL/inc/sys/alt_alarm.h:83: error: syntax error before "alt_u32" ./HAL/inc/sys/alt_alarm.h:84: warning: return type defaults to `int' ./HAL/inc/sys/alt_alarm.h:93: error: syntax error before "int" ./HAL/inc/sys/alt_alarm.h:93: error: syntax error before "nticks" ./HAL/inc/sys/alt_alarm.h:94: warning: return type defaults to `int' ./HAL/inc/sys/alt_alarm.h: In function `alt_sysclk_init': ./HAL/inc/sys/alt_alarm.h:97: error: `nticks' undeclared (first use in this function) ./HAL/inc/sys/alt_alarm.h:97: error: (Each undeclared identifier is reported only once ./HAL/inc/sys/alt_alarm.h:97: error: for each function it appears in.) ./HAL/inc/sys/alt_alarm.h: At top level: ./HAL/inc/sys/alt_alarm.h:110: error: syntax error before "alt_u32" ./HAL/inc/sys/alt_alarm.h:111: warning: return type defaults to `int' c:/NIOS-Download/niosii-ethernet-standard-3c25/software/test_bsp/HAL/src/alt_alarm_start.c:49:25: sys/alt_irq.h: No such file or directory c:/NIOS-Download/niosii-ethernet-standard-3c25/software/test_bsp/HAL/src/alt_alarm_start.c:77: error: syntax error before "alt_u32" c:/NIOS-Download/niosii-ethernet-standard-3c25/software/test_bsp/HAL/src/alt_alarm_start.c:78: error: `alt_alarm_start' declared as function returning a function c:/NIOS-Download/niosii-ethernet-standard-3c25/software/test_bsp/HAL/src/alt_alarm_start.c:79: error: syntax error before "void" c:/NIOS-Download/niosii-ethernet-standard-3c25/software/test_bsp/HAL/src/alt_alarm_start.c:82: warning: type defaults to `int' in declaration of `current_nticks' c:/NIOS-Download/niosii-ethernet-standard-3c25/software/test_bsp/HAL/src/alt_alarm_start.c:82: warning: data definition has no type or storage class c:/NIOS-Download/niosii-ethernet-standard-3c25/software/test_bsp/HAL/src/alt_alarm_start.c:84: error: syntax error before "if" c:/NIOS-Download/niosii-ethernet-standard-3c25/software/test_bsp/HAL/src/alt_alarm_start.c:91: warning: type defaults to `int' in declaration of `irq_context' c:/NIOS-Download/niosii-ethernet-standard-3c25/software/test_bsp/HAL/src/alt_alarm_start.c:91: warning: implicit declaration of function `alt_irq_disable_all' c:/NIOS-Download/niosii-ethernet-standard-3c25/software/test_bsp/HAL/src/alt_alarm_start.c:91: error: initializer element is not constant c:/NIOS-Download/niosii-ethernet-standard-3c25/software/test_bsp/HAL/src/alt_alarm_start.c:91: warning: data definition has no type or storage class c:/NIOS-Download/niosii-ethernet-standard-3c25/software/test_bsp/HAL/src/alt_alarm_start.c:93: warning: type defaults to `int' in declaration of `current_nticks' c:/NIOS-Download/niosii-ethernet-standard-3c25/software/test_bsp/HAL/src/alt_alarm_start.c:93: error: redefinition of 'current_nticks' c:/NIOS-Download/niosii-ethernet-standard-3c25/software/test_bsp/HAL/src/alt_alarm_start.c:82: error: previous definition of 'current_nticks' was here c:/NIOS-Download/niosii-ethernet-standard-3c25/software/test_bsp/HAL/src/alt_alarm_start.c:93: error: initializer element is not constant c:/NIOS-Download/niosii-ethernet-standard-3c25/software/test_bsp/HAL/src/alt_alarm_start.c:93: warning: data definition has no type or storage class c:/NIOS-Download/niosii-ethernet-standard-3c25/software/test_bsp/HAL/src/alt_alarm_start.c:95: error: syntax error before '->' token c:/NIOS-Download/niosii-ethernet-standard-3c25/software/test_bsp/HAL/src/alt_alarm_start.c:111: error: syntax error before '&' token c:/NIOS-Download/niosii-ethernet-standard-3c25/software/test_bsp/HAL/src/alt_alarm_start.c:111: warning: type defaults to `int' in declaration of `alt_llist_insert' c:/NIOS-Download/niosii-ethernet-standard-3c25/software/test_bsp/HAL/src/alt_alarm_start.c:111: warning: data definition has no type or storage class c:/NIOS-Download/niosii-ethernet-standard-3c25/software/test_bsp/HAL/src/alt_alarm_start.c:112: warning: type defaults to `int' in declaration of `alt_irq_enable_all' c:/NIOS-Download/niosii-ethernet-standard-3c25/software/test_bsp/HAL/src/alt_alarm_start.c:112: warning: parameter names (without types) in function declaration c:/NIOS-Download/niosii-ethernet-standard-3c25/software/test_bsp/HAL/src/alt_alarm_start.c:112: warning: data definition has no type or storage class c:/NIOS-Download/niosii-ethernet-standard-3c25/software/test_bsp/HAL/src/alt_alarm_start.c:114: error: syntax error before "return" {standard input}: Assembler messages: {standard input}:52: Error: symbol `current_nticks' is already defined make: *** [obj/HAL/src/alt_alarm_start.o] Error 1
