20 years agoBuilding NIOS2 Applications using command line
Hi everybody, we decided to use a NIOS2 core in our project and I'm facing the challenge, to build applications without the NIOS2-IDE. Since we do automated nightly builds and regression te...
20 years agoHi Jason,
thanks for your answer. We need to do both, tests on a development host and tests on the target. The appropriate executable is built according to a compiler switch. Anyway, your solution is much too complicated and it will cost a lot since you have to purchase new tools (Spy++) which do not run for example on Solaris or Linux. The Nios2 IDE is only a GUI which controls the NIOS2 command line based GNU-Tools. So, there must be a way to do it like I described it in my posting. Nevertheless thank you for your contribution Regards umberto http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
