20 years agoBuilding Linux application
Not sure if I should have put this under "Software discussion" or not, but here goes: I'm trying to build a Linux application using Altera's NIOS-II IDE with Microtronix plugin. The pro...
20 years agoShaChris23,
You should really work on Linux, a Makefile is not needed to build a simple program. Even you want a Makefile, you can write it in the way that you are familier. Check this link, http://forum.niosforum.com/forum/index.php?showtopic=3174 (http://forum.niosforum.com/forum/index.php?showtopic=3174)
