20 years agoBuilding Linux application
Not sure if I should have put this under "Software discussion" or not, but here goes: I'm trying to build a Linux application using Altera's NIOS-II IDE with Microtronix plugin. The pro...
20 years agoHi ShaChris23,
> Umm..as a newbie, I'm not sure about how to go on. I need some sort of guide on > how to create the makefile specifically for the Microtronix Linux app. Well ... you're in luck! The "Nios II Linux Reference Guide" is probably just the guide you need :-) It is in your altera/kits/nios2/documentation/linux directory. After reading the section, "Creating a Makefile", you can read through the many Makefiles in the examples tree -- it's not very exciting, but you'll probably find most of your answers there. Regards, --Scott
