21 years agobuilding library for ecos
I downloded the ecos release and tried to create a libray using the nios2configtool. The board configuration is a 1c12 Microtronix ukit. The following is the error message from the build script: (par...
21 years agoThis looks like you've tried to use the same eCos project for different PTF files.
Try doing a clean build of the project. If that doesn't work, post a copy of the PTF file to this forum. That may shed some further light on what's happening.
